Re: Water in lower while hoooked to a hose
If I understand your question correctly...yes that's right. The pump base (diagram #24 ) does fit snuggly. You definitely want to insure the large O-ring on the bottom of the base is well greased. Otherwise it may roll up as you press the base into place. I used Vaseline...but just about any multi-purpose grease will work. Also, be sure to wrap the drive shaft slines with a piece of masking tape to prevent damaging the seals/o-rings as you install them onto the shaft. I used some liquid dish soap to lube up the impeller as I installed it in the base housing...some guys just use grease for that.<br /><br />Anyway...you know the drill. Just go back together by the book...<br /><br />Walt
