water in fuel
phockeye
25 hp 2012 e tech can anyone describe the procedure to purge water contaminated fuel from the system I've already cleaned it out up to and including the the vapor canister and it's still cutting out after 3 or 4 minutes at WOT how the hell do I get all the water out of this thing?
sutor623
I like to connect the fuel line from the tank directly to you primer bulb and pump the fuel into a mason jar, until you see no more water. The water will settle to the bottom of the tank so if you let it set for a day or so you should be able to get it all out.
If you do this and there is no water in the mason jar, you have another issue.
