Erik-The-Red
Thread starter- Joined
- May 2, 2007
- 21
I rebuilt my starter and I got it working fine (thanks for that help on that), but when I tried to start the boat, it wouldn't. Turns over fine, started to spit and sputter for a second, acted like it was gonna run, but then nuthin'. Since the fuel pump sat under water along with the starter (flooded the rear of the boat, didn't know it, then it sat for a couple weeks), I figured I better pull the pump and have a look. It was full of water-saturated fuel, like a 50/50 mix. I took the pump apart and cleaned everything, but now I need to drain the fuel lines and the tank and start again fresh.
Whats the easiest way to drain the tank and get all the water out?
Also, is there a trick to getting the fuel pump back in? I can't seem to align the pump shaft arm thingy, doesn't wanna go in the block and let me line up the bolt holes to mount it-- feels like its hitting something in there. Do I need to rotate the engine to TDC or some such thing?
Thanks for any help!
BTW, this is a 2001 Glastron 175 SX w/ a Volvo Penta 3.0L. Thanks!
