dirty-fisherman
Thread starter- Joined
- May 22, 2009
- 2
I have a 1999 250 HP Mercruiser. I had the boat summerized and a starter changed about a month ago and the boat ran great in the shop. I took it to the lake last weekend and when I tried to start it the started had a grinding noise and would not turn the engine over. Back to the shop. My mechanic found a missing tooth on the ring gear so we pulled the motor and changed the ring gear. Tried to start and had the same grinding noise. pulled a spark plug to try turning the engine over and water came out. There is also water in the oil pan. The mechanic thinks that the block is cracked although he didn't do any further investigation. My questions are: is the block really cracked? I didnt think that water would get in the cylinders unless it was an intake or exhaust manifold or gasket, possibly a head? Could this have been winterized improperly? My biggest bafflement is that the boat ran at the time of start-up and then had issues after two weeks on its first spring voyage. Could the mechanic be jerking me around? I just want to make sure the block is cracked before I drop $5K. Thanks
1999 Rinker 212 Bowrider
250 HP Mercruiser w/ alpha one
