water in cylinders 5 and 7
dubge
well I found water in cylinder #5 and #7 :(
Now I do know this is going to be a big task to fix due to my lack of knowlage
SO with that being said what could it be and where should I start to look to solve this problem.
ANY input on this would be great
thanks
Ray
Haut Medoc
Re: water in cylinders 5 and 7
If you do not have water in your oil, it may not be as bad as you think.....
Pull the riser & man. on that side & pressure test them.....
My gyess is that the either the riser, manifold or the joint/gasket between them is bad......
If they are old replace them or pressure test them, if you must......;)​
dubge
well after doing some reading about this problem I saw people saying this could happen from stopping to quick in the water and water coming in that way. Is that true? I know I was doing that alot (new to inboards and didnt know that could happen)
The guy I bought the boat from said they were replaced last year I think, they dont look that old but again what do I know :)
thanks
dubge
oh and there is no water in the oil
dubge
How do I go about pressure testing them?
Also is it ok to run the boat for XX amount of time in a barrel and then recheck to see if they took on water again? I ordered a new starter and it will be here today so I have not started it up yet. Will I have any problems starting it?
Thanks
Haut Medoc
It should start....
If the mans are that new, most likely they are not a problem....
You can definately ingest water after a high speed shut down.....;)​
dubge
OK it started right up. I pulled all the plugs and cranked it over several times to make sure it got all the water out and changed all the plugs while I was at it, I ran it for about 15 mins submerged in a barrel of water then sprayed some seafoam into the carb and shut it down. I am going to pull the plugs to see if there is any water in there before I start it back up.
will running it this way let water in if in fact the problem is a leak?
thank you for the help
Haut Medoc
Yes, it will tell you if it has a leak,using the barrel...
Check it immediately, by pulling the two plugs that had water, if it is present again, you need to pull/test the man/riser.....;)​
dubge
well good news! No water in there :)
So I would guess that it got in there from my asinine driving.....er..ah....rather stoppping.
I will check it again next time out on the boat.
Man my last 2 boats were outboards and they seemed unstopable but this one seems to need a little more attention.....reminds me of an old 77 GMC I had.
Thanks again for all your help
Haut Medoc
As long as you keep the engine running you should not get water ingestion.....;)​
