Last time I took my boat out- as soon as I got it in the water and got in the boat I noticed the carpet was wet near the drivers seatfloor-- Drove it for a couple of hours and it got a little worse-- most of the carpet was wet. Once I got it back on the trailer I couldn't find any scrapes or holes anywhere in the hull-- After further inspection the only place I could find that it might be coming from was where the hull and the top half of the boat join together and there is the trim that goes all they way around-- I noticed the previous owner had caulked up under there at some point near the front of the boat. This would make sense as it had water immediately after putting it in when this part is right near the water line- (when I'm under way it is way too high above water) Any advice- Should I remove this piece and reseal it??
