Re: water in boat???
OK, just so you know I wasn't simply picking on you, there was not an attachment when I first looked . . .
If the water is not reaching the bilge, and you are positive, then the water did not come from the bilge either which is good. I still believe it might be left over from storage then. Can sideways rain get in there? Seriously, if you are 100% positive that water cannot get from the bilge area around the engine and to the locker then that takes the engine and bellows out of play (good). However, I would not trust that. Are you sure the bow was high enough to get water to drain back to the engine bilge area and that nothing came out with the plug out? Very, very important question.
Also, when all is done, you need the locker to drain to the aft bilge . . .
