Water in bilge has returned in 1995 Four Winns 190 Horizon
ggundersen3
I will begin investigating with the methods suggested by several of you. Thanks for the suggestions. I agree it's not right.
ggundersen3
Water in a boat after running is not normal. I had that very issue with my FourWinns when I first took delivery. After an hour on the water I'd pull the boat and the bilge pump would be spitting water up the launch ramp.
Turns out the selling marina were idiots - and that's being polite. Took it to a different marina and had them fix it. Pretty sure it was bellows that weren't tight.
So what I'd suggest is dunk the boat and while its on a trailer, check like Scott suggested. Then, lower the outdrive and start the motor. Now recheck for water. Bet you find it this way.
This is what I’m going to do. Makes sense. Thanks briangcc
