Gaetan Carrier
Thread starter- Joined
- Aug 30, 2010
- 8
Winterized 4.3L according to Mercruiser Manual but did something wrong because I have water in all cylinders. Cleaned all drain plugs to get complete drain down and refilled both block and manifold with RV anti-freeze.
This is the dry joint manifold design and I wonder if it's possible to have water trapped between in spacer between risers amd manifolds.
Want to pressure test block/heads using procedure for blocking all hoses to the thermostat housing and then pressurizing one oulet but it seems like I'd be putting presure to the closed thermostat and not the block.
I'll be be putting plenty of oil in all cylinders till I can repair.
