Water in #6cyl.
tkmichael11
While tearing apart the starboard side of my 228 merc. (to replace the starter) I pulled the spark plugs and #6 was full of water. Compression is good and the boat runs good. Before the starter went out, she was doing about 32mph at about 3400rpm. It idles good and take a bit of time to get on plane, but once its there, she is very smooth!
Where could this water be coming from and why only the #6cyl?
Re: Water in #6cyl.
Ayuh,....
Probably the Starboard Riser, or it's Gasket is Shot,+ #6 exhaust valve was open....
tkmichael11
Re: Water in #6cyl.
Thanks. I searched some of the threads in this forum and noticed the consensus for water in cylinders was probably due to a gasket failure either betweeen the riser and manifold or the manifold and the head.
I re-used the old gaskets, when putting everything back together, and I'm hoping that is the problem and nothing more serious.
The info is appreciated!
Re: Water in #6cyl.
noticed the consensus for water in cylinders was probably due to a gasket failure either betweeen the manifold and the head.
Nope,.....
Those gaskets see No Water,.... Just exhaust Gases.....
tkmichael11
Re: Water in #6cyl.
New gaskets installed.........Not a drop of water! Thanks for the help!!!
