water impeller
apager
I just bought a '86 evinrude 115. It has been setting up. I need to replace the impeller. I have completely rebuilt the lower unit on a stern drive but this is a little different. To take the lower unit off, do I only have to undo the lower unit bolts or is there any bolts or links I have to undo in the upper end to release anything. thanks
dkondelik
Re: water impeller
you may have a shift-shaft or shift-shaft-coupler to contend with. Your manual should give the details.
Kenny Bush
Re: water impeller
Apager, Everything comes loose from the bottom....Dont forget the trim tab too. I you successfully did the sterndrive, you should have no problems.......... :p :p :p
Jack Shellac
Re: water impeller
You also have to disconnect the shift rod. It's held with a retaining pin at the shift lever. BTW, OMC manual says to have the gears in REVERSE when you're dropping the gear case.
dick
Re: water impeller
<br />Sorry about the size but I wanted you to see the two types.You may have ether the V-4 / V-6 type.
