water hose
rebars1
I am restoring a 1971 merc 888 Ford 302, 188hp. I want to replace the water hose that runs from the transom plate to the engine water pump. The existing hose is "3/4"id standard heater hose". Is this the correct hose to use?
Don S
Re: water hose
The 3/4" heater hose will be fine if you are using the raw water pump in the outdrive. If you are using an engine mounted raw water pump, it wouldn't work.<br />When using the drives raw water pump, the hose "Normally" goes from the transom shield to a distribution housing on the intake, and does not go directly to the engine mounted circulation pump. (Note: there is a difference between circulation pump and water pump on marine engines)<br /><br />Here is a picture of the circulation pump on the 888 engine.<br />
Re: water hose
Originally posted by rebars1:<br /> I am restoring a 1971 merc 888 Ford 302, 188hp. I want to replace the water hose that runs from the transom plate to the engine water pump. The existing hose is "3/4"id standard heater hose". Is this the correct hose to use?
Ayuh...........<br />That's the stuff.......<br /><br />What Don is saying is,<br />Yes, You can push thru it,(your outdrive)<br />But,<br />No, you can't suck thru it(Bravo stlye cooling)....... It'll Collapse....... ;)
rebars1
Re: water hose
Thank you both for the input. You are correct, DonS, the hose goes to the distribution housing. The system is raw water pumped from the outdrive.
