water from prop
meha
Merc 130
alpha 1
I put the muffs on and started the engine and there was water coming out the center of the prop. Is this normal or am I in trouble? It never did that on my old boat. A 85 140 Merc on a Wellcraft. Thanks for the help
meha
Re: water from prop
it was out like it was the outlet from the motor
Don S
Re: water from prop
There are a couple of approx. 1" idle relief ports in the transom shield that the water normally comes out of when on muffs. Are the plugged up with anything? OR, there is less resistance to the water flow going out the prop. That is where most of the exhaust and water goes when on step anyway.
If you don't have any idle issues in the water and no overheat problems don't worry about it.
meha
Re: water from prop
Thanks, I was hoping it was normal on this outdrive. I'll find out more when I change the impeller
KRS
Banned
Re: water from prop
Just be sure to never get your prop wet !
(a little humor there)
