1977 25hp Johnson 25R77S<br />I've got water and what looks to be possibly exhaust in the gear case. Changed clutch dog and noticed water in the gear case after taking it out on the water, so I re-sealed the case and added new gear lube. Put it on the water again and then drained gear case to see if that fixed it. Had water again and this time noticed dark grey substance that had settled to bottom of otherwise clear gear lube. Recently serviced water pump. Made certain that housing and plate were well sealed. Is there anyplace else that water/exhaust may be getting from exhaust housing to gear case? Maybe where the drive shaft enters the gear case? Any ideas?<br /><br />Thanks,<br />Jim
