Water Drain Nipple???
D_Wilson
Today I was trolling with my 2002 6hp. I noticed there was no water coming out of the housing as usual. So I stopped the motor, removed the cover, and pulled of the rubber hose. I found a buch of small leaves, removed them, and the water began to flow as normal. I went to push the hose back on to the (nipple?) that is attached to the bottom of the housing and it pushed right out and floated somewhere to the bottom of my lake. So I'm wondering what part this is I need to replace, or if anyone has an idea of something else I can use. I now have to run the motor with the cover off and the hose dangling out the back. Perhaps a smaller OD tube??
Thanks
gejandsons
Re: Water Drain Nipple???
That part will probably be a dealer item, since not many have to be replaced.
