Water Control Valve Part # 0394407
copper1
I have an 1989 Evinrude 120, and I noticed that water is dripping out of the water control valve.
I have looked and the part is no longer available.
Can I just bypass the valve?
boobie
If you could find the parts cheap enough you could up date it to a newer motor.
Faztbullet
You cannot bypass valve as it what controlxs the poppet valve/t-stat in head. What you can do is use the cover,gasket,t-stat assy and spring from a 1990 70hp and replace the the t-stat/poppet you have a eliminate the water valve
