While fishing over the weekend my 1999 TJRX 2 stroke Yamaha 90/65 OB(ser#499966) went from running great to running on 2 cylinders. I pulled the cover and right away noticed there was water in the bottom of the tray. I pulled the plugs a #3 was fooled and had water drops on it. I started the engine and noticed that there was a bunch of water comming out of the head cover. I limped it back to the boat ramp on 2 cylinders and pulled it out of the water where I could look it over a bit better. Pulled the #3 again and it was oily/watery. I noticed that the lower right bolt that held the head cover on was just a stud (the bolt head was missing) So I'm guessing that there is my problem. I'm a decent wrench turner, Is this an easy fix? On a scale of 1-10 what is the difficulty? I'm assuming that I EZ out the stud out and replace the gasket? There looks to me to be a few gaskets on this head, do I replace all of them? Do they come in a kit? Anything that I need to know before I tear into this thing? Thanks you guys very much in advance for any and all help that is offered!!!
Here's the diagram and looks like I'm going to need #'s 32 and 33 right?
http://www.yamaha-motor.com/outboard/parts/home.aspx
step 1
utboard
step 2:1999 outboard
step 3: 90TJRX
then go to Cylinder crankcase
Wooly
step 1
step 3: 90TJRX
Wooly
