udm328is
- Jun 6, 2010
- 126
Hi all,
last week I took the top off the drive to look in there and check thisgs out. Yesterday and today I took the lower drive off and replaced the water pump, housing, seals even the sleeve that goes between the water pump and the intake tub which the last person had the conector piece backwards, so it was just sitting in there, and the whole shabang, and yes I remembered the little gasket where the lube travels through. I got everything hooked back up and put the drive back on. I applied the muffs, turned on the water, and then water began to come out of the top of the drive, luckily not into the gear area, but just straight back through where the cover attaches to the top of the drive. Does anyone have any idea as to what I did wrong, and what I need to do to fix it?
Thanks,
Eric
Thanks,
Eric
