water coming out carb
rocketman63
motor running great but have a little water coming out carb. Like milky fuel .Just in bottom two carbs But not in cylinders
Grub54891
First and foremost, what are we working on? There should be a model and serial number plate on the motor. Get us a bit more info and I'm sure others will chime in with ideas.
Gasoline needs heat to evaporate.------It gets that heat from the carburetor body.------Carburetor will be cold.----You might be looking at condensation.
rocketman63
top Two carbs show oil bottom one shows milky fuel coming out . Is there any way for water to enter carb other than The fuel line
