water circulating pump
rockypond
I have twin AQ170B volvo penta , I would like to if anyone rebuilds the engine circulating pumps or if there are parts to rebuild these units and instructions to go along with it. Thank you for replying rockypond.
captmello
Re: water circulating pump
I haven't heard of anyone doing a rebuild themselves, but if you google "auto water pump rebuilders", you'll find there are rebuilders out there.
dennis461
I'm going to rebuild my AQ131C pump.
As long as the body is in good shape, it goes like this;
1. remove two 16mm ID bushings, carefully
2. press in new bushings carefully.
3. Replace seal.
4. Optional, replace steel shaft with new one.
Looks like this
http://www.go2marine.com/docs/1/1/2/0/112038F-p.jpg
billbayliner
3. Replace seal.
Looks like this
Dennis, the OP is asking about the engine circulating pump!
I agree wtih Capmello. Try searching for a company that overhauls engine circulating pumps.
In years past, friction companies used to provide this service. This would be a company that rebuilds brake shoes, clutch discs, etc.
Don S
That's a raw water pump Dennis, he is talking about the circulation pump.
The new pump (831742) runs around 1400 bucks.
There are parts for them, you can order them from here at iboats Click here .
That $100 seal (460839) is ceramic and very easily broken.
