washer or not?
2trackers
Have a 50 hp bigfoot, was going to temporarily put on a 854340-a33 prop. when I put it on there is slack on the front between the tab washer and the prop. Have a 12-835467-1 thrust washer in back. What do Ineed in the front? thanks
Re: washer or not?
Ayuh,... I donno what yer part #s mean,...
But,...
Generally speakin',...
Different props need different hardware "Kits" to work on whatever propshaft you're tryin' to put it on...
2trackers
Re: washer or not?
I did some research and think I found an answer. On "A30" props that don't use flo torq II, use kit #11-827614a or if you have the other hardware use "castle washer #12-31211a or sierra #18-3714
