40HP 2006-2007 mercury 40HP 4 stroke.
THE GOOD
-idles in neutral good when cold
-letting it sit out of water with flush hose attached for 30 mintues and moving in to fwd/rev OK
-LU is good (as per merc service center) and has oil
-unit is under warranty
THE BAD
-Makes a whiring noise in neutral after being put under load....1/2 throttle 1/8th of mile
-noise goes away in gear
-noise goes away after being turned off for sometime but quickly returns after running boat under load again and then putting in neutral.
-Dealer tells me this is normal on the optimax ans verado....this is a regular 40HP unit
and its still under warranty for a few years, they cant see any physical damage....thats not helping me.
-The dealer pretty much deals with large inboards only....they are not outboard savvy.
What is normal? I have only come across one other post on this, the guy ended up selling it:
http://continuouswave.com/ubb/Forum4/HTML/003121.html
I need help to get this issue settled. Please help!
the boat baby
THE GOOD
THE BAD
the boat baby
