Warning, not your typical Chieftain 'build'
jbcurt00
If you choose to open this topic, be aware, you were warned :grumpy:
Posted on another boating forum, apparently by the proud owner/builder
:grumpy:
:blue:
To each his own, and I guess a case could be made that it is still IN use, and probably enjoyed by those that board her
:confused:
:mad-new:
Again, I apologize for posting the following
treeboat.jpg~original
:facepalm:
Text:
On the Rock River, just north of Rockford/Machesney Park, IL. Boat tree house with attached swing, jungle gym and if you look close, a slide on the other side. Raised up to prevent it from floating away in a flood!
Watermann
:grumpy: what a waste... :facepalm:
I'll one up you though, this will make you guys sick to your stomach. :eek:
GA_Boater
:facepalm::doh::facepalm::doh::facepalm::doh::facepalm::doh::facepalm::doh::facepalm::doh::facepalm::doh:
jbcurt00
Bummer about the SC, but man, there were at least 2 vintage trailers wrecked that I know guys are hunting for................
dozerII
Wow, did you see the hack job on the back end of the S/C in the race:eek:, novel Idea for a tree house
