saxmanbrad
Thread starter- Joined
- Jan 15, 2012
- 9
Hey guys, I need some advice! I was out running @ 2500 RPM the other day and I started getting a warning horn @ every second...if I stopped, it would go away. Back on plane, warning horn, and so on. Eventually, I think the engine went into SLOW mode as I was limping back to the dock. At this point, I am figuring the engine overheated a bit.....pee stream is strong. Messed around with it today...at idle, starboard bank intermittently (as in different engine runs) runs real hot...@ 170-180 at idle or high idle (using an infared thermo). At this point I'm thinking starboard thermostat is bad. Out of curiosity, I disconnected the the temp sensor leads at the heads, and the horn went off again, with both banks @ 145 at idle. Now I am really confused. Just to clarify, it is about one beep per second, not constant beep. At this point I am thinking a fuel restriction to the starboard bank is causing overheating in that bank? Any help would be greatly appreciated! (Also, even when the engine is idling @ 145, starboard bank second cylinder down is running about 10 to 15 degrees hotter then all the rest.)
