I have a 1988 90 horse VRO outboard. I replaced the warning horn last year because for whatever reason, it melted! This year when taking it out of storage the horn is a constant on with the key on and the engine not running. I unplugged the engine temp sensors and the oil level sensor and also the three wire VRO plug, all unplugged now. The horn is still constant on. I started the engine and let it run for about 30 seconds while out of the water to run the oil pump. I did get the usual blue two-stroke smoke out of the exhaust by the prop so I'm sure it was pumping oil. The horn was still a constant on. Any ideas?
