warning buzzer
nonstopgo68
finally got my 86 40hp johnson to fire up and run on muffs. i think its been like 17 years . amazing :D
it ran and idled pretty good . then i heard a buzzer and now it wont fire back up
can somebody tell me what this means.
i used to hear this buzzer when id first try to crank before i changed vro to mix
tashasdaddy
Re: warning buzzer
did you do Awakening a Sleeping Outboard, in the TOP SECRET FILE? change impeller, clean carbs. new fuel lines, checked spark???????
nonstopgo68
Re: warning buzzer
yes i did all that and more , thanks great info btw.
changed to fuel pump and mix and found bad rectifier.
didnt realize it had a lanyard missing on remote.
nonstopgo68
Re: warning buzzer
to be totally honest havent been around boats since i was a kid.
not really sure what the controls on the remote are.
i know about the primer solenoid and the forward and reverse
but the lever that lifts straight up, is that the throttle?
