Re: warm starting procedure
GN l,<br /><br />It should not be necessary to reprime. The bilb should remain somewhat firm. If it does not, the bulb may be leaking past its internal check valve, or, the needle valves in the carb (s) are starting to leak. Primer bulbs are cheap.<br /><br />If the carb. needle valves leak, they will flood the engine. Does it smoke alot when it does start?
