Warm or Cold Hard starting 1973 Johnson 135 powershift 2.
Goodtimecharlie
I promise I have searched all of the forums to try and find an answer for this issue.
I have recently rebuilt the carburetors on this engine and despite my best efforts, I still have an issue getting this engine to start whether hot or cold. Once I do get the engine running, it idles perfectly, will run at wide open throttle, and never stalls through gear shifts, Etc. I recently put a fuel soaked rag over the intake, and it fires up very reliably. I know this isn't safe, so please help me figure out why this engine is so hard to start. I checked the fuel pump and think it might be the problem. But any insight is very welcome.
The fuel pump starts working once the engine has started !---------So is the THERMO ELECTRIC CHOKE set-op still in service , yes , no , do not know ?--------Is the choke solenoid working ?--------Is the choke solenoid properly adjusted ?----------Finally are the starter / battery / battery cables in good condition ?-----There is a lever for CHOKE ON / CHOKE AUTOMATIC / CHOKE OFF.----Is that in the correct position ?
