wards seaking 1969 need help pleas
dains
hi i need some help adjusting the carb it will only run for a few seconds and thats if i pump gas into the carb need to know the needle valve setting i think they are all out of wack either flooding the motor or not getting the right amount of fuel model is vwb29906a and serial is 96x 11247 and also fuel to oil ratio and what octain if it matters only paid 100 dollars for motor but just cant get it runnig right need help .
narwhals
Re: wards seaking 1969 need help pleas
welcome to iboats dains, if your numbers are correct the normal initial settings for your carb are one turn out from the seated position on both idle and high speed.the seated position refers to screwing in the neddles until snug then backing them out do not overtighten or you will risk destroying your carb or jets.carb must be readjusted under load, after motor is warm. if this does't work i suggest doing a thorough carb cleaning and reassembly. if you need more help, simply reply to your post.good luck.
dains
thanks will try bought carb cleaner to day what is the mix ratio on gas to oil on it been mix 50 to 1 but dont want to damage it
dains
it worked thank u runs like a champ but the spring that retracts the rope broke so i have to hand wind it but at least it starts in a couple of pulls any idea were to find one of those or an electric starter wishfull thinking
narwhals
if your pretty hand ,you could take the recoil apart, and inspect it. a lot of times the tab or tang will snap off or it will get straightened out by pulling so many times. if this is the problem you can simply rebend a new tab and put it back together. recoiling the spring sometimes gets a little tricky so if you have a pair of vise grips to hold it in place when putting the rope back on this is helpful or a second pair of hands. good luck
dains
no not the case it broke about an inch worth of coils off the bottom i tried to strech it and bend a new loop but just cant get it to work i think it has to be about the same length as the tube so might need a new one but i guess in till then ill wrap the rope and start it that way
narwhals
sorry to here that, sometimes they break just right, that its a quick fix. hopefully it starts on the first or second pull.
dains
any one know were to get a recoil spring for this or one that is compatible
