want to shop on iboats (need help)
mh11
Hello there, I would like to shop on iboats after all the help everyone has given me, and since I went to three local stores in town this past saturday, two of which were closed, and the other didn't have what I needed.:mad:
I want to make sure I am ordering the right parts, hence I need some help.
1978 Galaxie 22xl with merc 260, chevy crate motor.
I have 1/4" NPT elbows and want to replace the anti-siphon valves.
Should I order (2) part # 033801-10? I have two tanks
I want to replace the fuel hoses.
Should I order (3) part # 16-360-0143? Want to make sure I have enough
I need to replace the clear hose that goes from the trim pump to the reverse lock out valve.
Should I order 18-2126? Does that include the fittings that I need?
I need to replace the hose going from the trim pump bottom, sort of braided to the transom, it is shot.
Should I order 18-2107?
I need to replace the manifold to riser gaskets, I have the old log style manifolds with aqua power 5701 risers.
Should I order (2) part # 18-2833?
Thanks for the help, please let me know, and I will place my order.
