want to check rockers
bandit86
Banned
87 omc 5.7heard something ticking, I want to pull the rocker cover off but the riser (name??) sits on the exhaust manifold looks to be in the way, if I take it off, can I use high heat silicone to seal it up? ot should I just take the whole manifold off?
Reel Poor
Re: want to check rockers
Take the manifold and riser off as an assembly.
You cannot use sealer between the riser and the manifold.
How was your oil pressure?
bandit86
Banned
it was flickering, but I think it was just the gauge, at some points it stays at 0 and doesnt move then shoots right up to 40psi, comes and goes with the waves
Scaaty
Did ya check the oil? Ya got a lifter ticking...aint a rocker. And a gauge that fluctutes is low oil in waves
Reel Poor
Valve noise is usually the first sign of low or no oil pressure. I would recommend installing a mechanical oil pressure guage to the engine and see what the pressure reads.
Did you check the oil level?
bandit86
Banned
half way up on the dipstick when that happened,
Don S
There is your problem, the oil is over filled. This allows the crankshaft to hit the oil and areate the oil. The air bubbles get in the lifters and and won't hold pressure and they tick. The oil pressure fluctuates also because of the air.
Drain the oil down to the full mark and see what happens.
The other question is why is it too full?
bandit86
Banned
sorry, I meant half way up between the two marks on the dipstick. and it only sounds like one lifter, but ticking pretty loud though.
bandit86
Banned
it's what it sounds like, but still want to verify before trailering the boat home to work on it. would an automotive lifter survive the marine enviroment / use?
