Fishsqueezer
- Apr 5, 2012
- 28
I?m using the Mercury service manual for my engine (Mariner 50 hp, 4 cyl, 2 stroke, electric start, SN. 6542853), but I?m still having a few issues.
I installed a new white plastic float which only has one metal adjustment tab for float level, but no way to adjust drop. I?ve been able to get the float level correct by bending the metal tab which contacts the inlet needle spring, but float drop is not on target. The book advises installing a new float if drop is not correct since the white plastic floats are not adjustable in both directions. However, this float is new, yet it does not drop all the way! The float bottoms out against the carb body at a distance of 3/32? from the main jet. The factory manual specifies a distance of 1/32? to 1/16? between float bottom and main jet. What should or can I do about this issue? Is this a big problem? I know carbs are very finicky.
Anyone have wisdom on this issue?
