gm280
Thread starter- Joined
- Jun 26, 2011
- 14,605
Okay, I tried this a few days ago and apparently it didn't take. Or if it did the powers at be can delete this.
I have an older Kohler CV15S engine on my lawn mower with a Walbro LMK carb. It started leaking some years ago now and even after installing a few rebuild kits in hopes to stop the leak, it still does. I know exactly what the problem is but was wondering if others had the same problem being how it is a known problem with that type carb all over the web. Seems the standard rebuilt kits include a new needle but not the actual brass seat. And so Walbro came out with a kit well after the problem because known to fix their leaking carbs with a seat kit for only $35 dollars...a third of the price of a new carb and it is merely a screw and a new brass seat. I see some videos that folks use a Q-tip with some polishing compound and literally polish the seat back to a good finish to stop the leak. Has anybody actually done that or even installed their new brass seat in their carb? I have a work around but it is a PITA to remember to turn OFF and ON the fuel valve each and every time... If I forget to turn OFF the fuel valve I installed as my work around after I am finish cutting the lawn, then I get to drain the crankcase oil and filter and install fresh oil and a new filter next try because the carb allowed gas to get into the crankcase. Anybody? :frusty:
