Waking up the boat after the long winter slumber
chiefalen
Ok guy and gals, i have been getting restless, and more and more, my mind turns to waking the boat up after it's long winter slumber.
So i say to myself, myself whats the first thing your gonna do, when you yank that boat out of the backyard and onto the driveway, into it's prized spot right in front of the right garage door.
My 2 cents, every year when i pull the boat out from the backyard the first thing i do is go thru the fuel system.
I first pull the fuel pickup tube, and stick the clear hose i have attached to a dc electric fuel pump i keep onboard the boat into the tank way back into the farthest corner and i lift the bow up as far as it will go.
I pump the water and gunk out of the tank, till i see fresh gas in the clear tube, usually about a quart full of gas and gunk into the clear container, and shut off the pump, pull the line and blow thru the anti-syphin valve to make sure it's working good and nothing is gunking it up.
Then i move on to the fuel water separator, new filter, fuel pump, mine has a filter in it and i clean it. Then i move on to the fitting at the carb and clean that filter.
This is all done before i ever start the boat so i know i'm starting with a clean fuel system.
Now to do all this takes me about a half hour to 45 minutes, and i know it's sounds like it's a waste of time, but i have a old boat, and it has sat over the winter, and in my mind it's worth the time.
Above is a post from another forum i just left.
The second thing i do is install the drain plugs.
The third, check the oil in the motor.
The fourth is pull the dizzy cap and lightly sand the points and replace the cap. I don't do the tuneup yet at this point, but i do have the new kit to install new points and condenser, and plugs. And no i don't put new plugs every year, i do pull each one clean them and re-gap them and reinstall them, every 2 years i install new ones.
Then i move on to the drive and check the oil.
Thats when i put water to the drive, and remove the flame arrester and dribble a few drops of fuel in the carb and start the ole girl up.
I look everywhere to see if the motor froze even though i know i winterized it right. No water dripping, no broken hoses or cracks. Off with the motor, off with the water going to the drive. Check the motor oil once more for water and level. And i pull the rabbit ears and let the drive drain. Belt good, everything good, then life is good.
Tune up maybe the same day, maybe the next day depends on the honey to do list. But it will get tuned up before i go on the water.
The above is what i do, and not intended for others to follow in my footsteps.
But is my start up.
I like to get started about 2 weeks before i intend to go on the water, in case something is amiss and i can get it sorted out and fixed, so when i do go on the water, i have all the uscg equipment onboard, my radio checked, and my handheld radio charged and in the proper holder, i keep 2 raidos onboard.
Good luck people with your start ups, hope they go well.
ziggy
Re: Waking up the boat after the long winter slumber
i ususally start by reading my service manual and do what it says. then i read dons' summerization thread and do that.
this year i get to put by bellhousing back on prior to anything as it got stored w/o so i could do the water hose a second time for not doing it right the first time, then the drive.
if all goes well and she's ready to go. i do the fun part last. putting all the gear back inside it. then off i go for a first splash...
most seasons it seems like around end or march or early april for me here in nebraska. this year, i'm guessing it'll be mid april so i can get the work done. sure hope all goes well so i don't have to spend a lot as i ain't got a lot to spend... time will tell.. good luck to all in their summerization process..
bigbob_FTW
our winter only lasts a couple of weeks! :D We'll be skiing by Easter. :p
chiefalen
It's been slow on the forum these days is why i thought maybe he will allow a getting ready thread to slip thru.
Texas is nice my brother lives in Waxahatchie < probably spelled wrong.
I enjoyed my few years living in Texas in my youth. Thats why my brother moved there 30 + years ago he came to visit me on vacation and decided thats where he wanted to live..
Alot of boating goes on there.
One of the few places that winterization of boats are few and far between.
a70eliminator
Chiefalen, you of all people put your boat away with an empty tank of gunk and a sour fuel seperator, I store mine with a full tank of gas and a clean new seperator, it's ready to go. All I'm contemplating is putting the block and manifold drains back re-attaching the hoses and starting it up on external water bringing up to temp check for leaks, if all that is good than I'm ready to go, but i'll probably tinker around with stuff for another month or two in no peticular order.
chiefalen
Nope full tank of gas i'm afraid of water condensation.
meesh
I'm with a70eliminator, full tank of gas and you'll have no condensation.
fat fanny
I'm w/ the Chief no gas! Strangly enough our process's are almost identicle. Living in northeast Ohio I like to take my time with both the lay up process and the gettin her ready. My girl will be 13 in the spring and I want her to get old with me That's why I love this forum. This year I have learned things I should have been doing that I haven't especially with the outdrive as far as regular PM. This winter I have read here more than post but with the upcoming season and outdrive checks and maintenance I will be posting like crazy do to @ this time I'm as dumb as a bag of hammers when it come to the outdrive. What does a decent seperator run for my 3.0LX (1996) carburated ?.Seems like a good investment.
Dshow
I've always heard to fill'er up before bedtime to avoid condensation...
abj87
I disagree on the need to replace points and condenser. If there serviceable there is NO need to replace every year. And i don't replace plugs till there worn. In an auto application they easily last 15,000 miles which translates to several hundred hrs.
tefu
Hi,
I'm new to the forum today, was reading about the gas tanks being full or empty, I have always been told to fill the tank up to avoid condensation, something about vapor space at the top of the tank. I have a 17ft 91 Four Winns w/ a 2.3L Ford OMC Cobra out drive. Starting having problems with the motor and it's driving me crazy. Just needed a little help to figure out the issue. If theres any body that is willing?
tefu
Any how, like I said it's really getting to me, I have always had no problem fixing motors but I guess it's just the boat thing. I have had the boat about a year now and things are starting to happen. The motor starting skipping at higher RPM's, get up on plane say around 3/4 thottle and it fills like a miss fire of one the plugs. I have changed the plugs, wires cleaned the points and checked all the wireing for corrosion. Any thoughts?
Don S
Tefu
First of all, welcome to the iboats forums.
If you have a particular question, feel free to ask it in a new thread of your own.
Asking in the middle of someones elses thead on a completely different subject is not the way to get your question seen and/or answered.
tefu
Sorry,
Trying to find out how to do this. I'll try that.
Thanks,
chiefalen
I fill her up before i put her to sleep. And all summer i i fill her up on the way home from the ramp.
Replicant71
You might want to look into a portable tank cleaner (just do an online search for "portable tank cleaning units") to flush/clean the fuel that's been sitting in your tank. Just a suggestion. Thanks for reading.
Navy Jr.
As a newbie boater last year, and with a factory new boat at that, I decided to pay the dealer for the winterizing. Someone told me it's a good idea to let them do it the first year.
When I asked what I need to do in the spring before using it the first time, the reply was, "Hook up the battery, put new line on your reel and go fishing. Nothing special."
Oh, and it has a full tank of fuel on board with stabilizer added by the dealer.
Keeping fingers crossed. "Sweetheart" doesn't come out of storage 'till May 1st, a couple of weeks after usual ice out in these parts.
chiefalen
If i were you i would make sure the plugs are in. Sometimes they ain't.
The hoses all hooked up? Make sure you start it in the driveway first, some guy just discovered the guys who winterized his boat, bent the throttle cable and it was running like crazy at high rpm.
Make sure you put water to it in the driveway.
Navy Jr.
Thanks Chiefalen. Yes, I'll remove the cowling and check for the obvious. I've never hooked the garden hose up to the receptacle on the back of the motor and run the motor that way before, but there are pretty good instructions in the Mercury owner's manual on how to do it, so maybe I'll give it a try. I imagine it will be pretty noisy, right?
chiefalen
Yes, but whats a little noise to us guys. Better to find out in the driveway there is a problem then at the ramp.
I have been running around myself getting peoples boat ready, funny today i messed with my trailer, and tires, but haven't got inside yet.
I want a 60-65 degree day to do my whole day thing with it then it will be ready.
Good luck !
