wacky trim guage
buckw13
I'm having an issue with my tilt/trim buttons and guage. THe baot is a 1990 larson senza 210 lx br w/ a 350 mercruiser. First off the tilt switch and the throttle arm will only raise the motor. Then the tilt switch on the dash will only lower the motor. So i was using it this way and the guage seemed to be working fine the when i had the motor all the way down it would show the needle all the way then it would go right past up to the up. Not sure if is the guage. The boat has a full instrument panel with all the guages in it. Just looking for some ideas how i could check this guage out and the switches out. I checked the swiches for continuity and the seem to be working ok. any ideas would be greatly appreciated. THANK YOU
