I have an 87 evinrude 120 4carbs with VRO disconnected running at 50:1 runs great wide-open loads up during idle. Checked plugs, compression, cleaned carbs made sure throttle valves is closed at idle adjusted needle jet screws. I have seen several posts were everybody has problems after disconnecting VRO. I understand that when in an idle mode the VRO changed the mixture to 100:1. What can I do to fix this very frustrating problem.
