FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a 1984 Johnson V-4 90hp motor, J90MLCRD. Can I convert the VRO like the Forum in top secret says, I guess you disconnect the oil line, and still use the VRO only for the fuel, but at a pre-mix. Can I do this with my model year engine?
yes..be sure to pump mixed fuel through the lines so you do not run your motor on straight gas..even for a short time. best to disconnect VRO after running engine until mixed gas is running through carbs...if VRO has failed you can manually pump fuel into carbs through lines.
