VRO to premix
montelltx
I have a 1991 Evinrude 70 VRO. Which manual fuel pump will convert and the exact steps to convertion. Thanks in advance.
Daviet
Re: VRO to premix
You might try running a search, I think there are several posts on how to do it.
guy74
Re: VRO to premix
When I converted my 1988 60hp Johnson, I used the pump from an older version of the 3 cylinder motor. PN 0385784. You have to remove the pulse limiter fitting, and replace it with a simple hosebarb. I just wrapped the pump in foam and let it lay in the bottom of the housing under the carbs. Has been working fine for the last 4 years. If you have anymore questions just ask here, lots of great info on the board!
guy74
Re: VRO to premix
That is the right style of pump, should work. That pump is for 20-30hp, it might not flow enough for the larger engine.
montelltx
Re: VRO to premix
I should have said VRO housing is cracked and need correct Sierra manual pump part number.
montelltx
Re: VRO to premix
Thanks for all the help. I got the right pump #438559 from dealer it has 3 nipples and I have 4 hose ends please help.
