Re: vro pump. replace or not?
yes i can rebuild it but is it worth it. the oil pump side works perfectly. it leaks from the fuel side from the first diaphram. i inspect the diaphram and it has no cracks or pin hole that i can tell. the piston seems to be in proper order. i cant figure out why it is leaking.
