dajohnson53
Thread starter- Joined
- Apr 28, 2004
- 1,627
J200TXESM.
Condensed version: local shop replaced air motor diaphragm on VRO2 pump, installed new pulse limiter and now it is burning oil at 100:1 rate. Was at about 60:1 before this. I will call shop about this Monday, but in the mean time would like to get IBoats wisdom and advise.
Long version:
Bought engine last year, very low hours, very clean. Appears to have original VRO2 pump. Ran perfectly - good start, good idle, good accceleration, good cruise, proper WOT RPMS.
Marked oil tank and it was consuming oil at an average of right about 60:1 which seemed normal to me because this VRO2 pump is supposed to go 100:1 at idle and about 50:1 at WOT.
Since this was an old pump, based on things I've read here, I decided to replace the VRO2 pump with a current OMS pump and replace the old (black face) pulse limiter with a current (blue face) pulse limiter.
Brought to a reputable local shop and after looking at the pump, and hearing my experience, they suggested I save $$ - he suggested that they simply replace the fuel motor diaphragm because the old one was delaminating... a $41 part rather than the expensive OMS pump. According to the work order they:
Replaced Air motor diaphragm (p/n 435921)
Replaced pulse limiter and pulse hose
installed proper clamps
Used 50:1 fuel w/ on -water test
Water test - Verified oil delivery
verified "no oil" alarm.
Reinstalled, purged, etc. oil line.
Also checked compression 92-95 psi all 6.
I've been running 50:1 and will continue to run at least 75:1 until I get this sorted out.
I ran 56 gallons through it over 2 days this weekend and burned approximately 2.25 quarts of oil (between 2 and 2.5). This is almost exactly 100:1. My usage was about 75% fast cruising at ~4,000 - 4,500 rpm, and about 25% idle rpms (~800-1,000). I would have expected 60:1 oil burning rate again.
I got 2 or 3 "no oil" alarms (1 sec. intervals) first day which went away with a quick squeeze of the oil bulb. Second day, I pumped the oil bulb before first start, but not again, and didn't get an alarm all day. Several starts, rests, and a lot of running time (at least 2-3 hours).
Engine ran perfectly both days: easy start, good idle, good acceleration, full WOT rpms. No overheat or fuel restriction alarms.
I'll double check the oil line for anything that could be causing the no oil alarm, but I'm not too concerned with that at this time as it seemed to resolve and is easy to "fix" on the water. Frankly, I'm glad to know it works!
I'm concerned about the oil consumption. What would cause such a low mixing ratio? It seems "stuck" at the 100:1 idle ratio and not increasing w/ higher rpms.
Like I said, I'll call the shop Monday, but in the mean time, I'd like to know what you-all think and maybe even solve the problem myself. I do have an OEM shop manual.
If the pulse limiter/hose or air motor diaphragm they installed weren't working correctly, wouldn't that affect the gasoline as well as the oil flow rate? Wouldn't I be seeing general fuel delivery issues, not just the oil side? I can certainly visually check the connection of pulse line.
Do you think it's at all related to the pulse limiter and pulse line?
Do you think the oil side is just worn out and it is only a coincidence that it happened after the work the shop did?
Do you think the shop made a mistake and I should expect they give me priority service and fix it for free? This is a place with at least a week waiting time normally. I'd rather continue to mix the fuel and wait until fall rather than lose use of the boat for 2 weeks in July!. Or if there's some simple possible solutions, I would rather just fix it myself.
If so, and I decide to go ahead with my original idea of putting on a brand new OMS, it seems like that's a pretty straight forward DIY? Looks like it to me. The only reason I brought it to the shop in the first place, was because on my engine getting to the pulse limiter looks like a tough job for an amateur (removing other parts to get at it... that always causes trouble for me!) and I decided to let the pros do it. I think that if it's only a new fuel pump (OMS), everything looks straight forwrd.
Long version:
