My VRO system on my "91" 40 Johnson currently works fine ! I was doing some cleaning and noticed the power leads going into the pump system.( for lack of proper terminology)Both wires have lost the insulation near the ends and exposed copper is visable. Pulled the pump out of the Oil tank and tried to split the upper section where the leads entered the upper case.Tried to split the case but couldn't.I did not want to use force.I could tell it must come apart because there are two screws underneath and a gasket between them. My question is this, can the wires be reworked and re-attached at that point? Or is this something that must be replaced as a whole unit.And what would be the best way to split this thing apart without breaking it ? Thanks for all!
