VP Exhaust Leak
lanegl
Hello,
I just got a new to me 2009 Four Winns SL262 with a VP 8.1 Gi and I started noticing I was getting a lot of water that needed to be pumped out at higher RPMs (>1500). At the dock with the engine on I can't see anything leaking but last night I opened the engine compartment while at speed and took the attached pictures of water dripping out from what looks to be a sensor coming off the exhause? I apologize I'm not overly mechanical but just looking for some guidance here on why it's only coming out under more pressure and this is a sign of a more serious problem aside from a clamp replacement. Thank you for any help.
is it the rubber exhaust hose leaking or the corsa diverter leaking at the shaft?
remove the diverter assembly
pull the bell-crank assembly apart on the bench
replace the o-rings
reassemble
go boating
lanegl
replace the o-rings
reassemble
go boating
Thanks! Looks like CORSA is actually pretty helpful with sending free O-rings and instructions as well I found while researching.
if you had an over-heat, the rubber bits in the exhaust get burned up.
