vovlo sx conversion to duo prop
mattbags
My motor is the 4.3 with a sx-c1 drive with 1.79 gear ratio. I want to change to a duo prop. Do I need to change to a higher gear like the 2.30 that came factory with the dup prop boats or just leave the 1.79 gears in it and get different props? I did search but found nothing specific. from what I have found with the sx-c1 lower unit I can just find a dp-s lower unit and swap them. IS this corrct in my findings?
slasmith1
Re: vovlo sx conversion to duo prop
Just the lower is different. The question would be is the boat you are doing this to worth the cost. Just the props are going to run you about $1300 if you can find a set used.
mattbags
I'm trying to find the quote from dons about "worth to you". For what I have into it I'm still on the good side.
Don S
You will need the complete 2.30 lower unit and a set of props. Understand, the lower units for a duoprop drive has two counter rotating shafts, unlike the single prop drives with only 1 shaft. You can't just put a set of duoprops on a single prop drive.
mattbags
what do you mean complete lower unit? I have changed plans. I found a 1.60 complete drive. So I am going to take the lower off of that drive and put it on my 1.79 upper drive. Should be a simple swap correct?
Don S
Can you find the Volvo SN for the outdrive or any other numbers on the outdrive?
mattbags
The numbers on mine are.
Prod# 3858720
Ser# T0821389
Don S
Now I'm finding info on it. It should be an SX-C2, not a C1, The spec number is probably 3868720 not a 385 Volvo nor OMC used a 385 number. You also have the OMC version, not Volvo. The T08 serial number told me that.
Anyway, the 1.79 was used on the 4.3, the 1.60 drive was used on the 5.0L V8, and is the wrong gear ratio for a 4.3L engine.
mattbags
yeah it was hard to tell if its a 5 or 6. Thank you don. So does that mean I'm SOL on just using the lower from the 1.60 drive? On the motor tag it says
TSK SX-c1 (gas). Also original owner said motor was replaced about 3 years ago.
Don S
What year is your boat? And no, you can't use the 1.60 lower, that's where the gear ratio changes, not in the upper.
Don S
That drive number (3868720) is for a 98.
Don S
I was just looking at the OMC specs for 96, and there were no 1.79 gear ratio drives then. They were using a 1.66. So you may get away with using a 1.60, but you will probably have to reprop.
mattbags
Even better haha. I might as well give you the number on the engine.
4112016220 4.3gl pnca are the numbers I can make out.
I think these numbers are the transom shield numbers 4111534965 and 3868404
mattbags
I was looking thru the seloc book the wife got me and the 1.79 didnt show up til '98. (the oem manuals have not arrived yet)
Don S
4112016220 & 4111534965
Those, are Volvo serial numbers. The engine is a 96 (NC is the model designation). If you look up in the Adults only sticky in the Volvo secetion you will find manuals for the engine and drive.
mattbags
Well with the drive being a 98. What drive manual would I look at? Still the NC SX or with it being a 98 would it be a sx-m?
mattbags
Thank you very much Don. I think I found another complete drive. It is a 1.66 which came on those boats in my year range. I'm still trying to find the duoprop setup in my price range though.
Don S
Sure hope you find one. If you do, you can expect to feel like you put a bigger engine in your boat. Much better hole shot, lower rpm at same speed, low speed control both forward and reverse are WAY better. You won't believe it's the same boat.
