Re: Vovlo Penta AQ170 water in oil.
If the bolts are still in good shape there's no reason to replace them. I'd use a little (!) compound to cope with minor scratches in the surfaces but just a thin line.<br /><br />Check my previous post regarding torques. I think it's important to clean and oil the threads as the torque setting must no be affected by dirt.<br /><br />Also remember that valve clearance should be as specified - better a little too distant than too close.<br /><br />Did you find any signs of leaking around the water pump?
