- Sep 26, 2009
- 20,432
Re: Vote in my poll....just finished bearings...
I'm a firm believer in buddies. I have them on both of my boat trailers. One, is a tandem axle trailer with a 4000#+ boat on it. I haven't looked at the bearings or replaced the seals since they were new in 1994. I just keep grabbing the hubs to make sure I don't generate excessive heat. The reason seals blow with buddies is because people pump too much grease in them. They think a little grease is good and a lot is better. Wrong! I put just enough in as to move the outer plate that the grease fitting is on. Usually only takes a couple of pumps with the grease gun. My dad has buddies too and has never replaced seals or bearings either. His trailer is a 1988. How often you grease them depends on often or how far down the road you go...
