2001 Johnson 40 that VOR pump was capped off and went back to mixing oil. Years after running fine I was having an issue of the engine not picking up RPM's when accelerating. Then had the carbs rebuilt, all new filters, ball and rubber lines replaced. Ran fine on first outing then the same issue returned. Pulled carbs and found rubber in the lower bowl. My mechanic is sure the VOR is desecrating since the rubber came through after the in-line filter.
Question, does that sound right? I hear that there is a fuel pump only replacement for the VOR. What is the best replacement for the VOR?
Thanks for your help...
