volvo sx stall
J man
97 4-winns Volvo SX 350 TBI EST Starts and runs for approx 30 sec then stalls ign module was bad when started changed also changed plugs cap and rotor does not run out of fuel TPS working Coolant temp sensor working please help
bigbrownbuku
Master Chief Petty Officer
Re: volvo sx stall
what does the engine do as it stalls, is it like flicking a switch, does it gradually die, does it make any odd noises?
bruceb58
Re: volvo sx stall
What is your full model number?
first thing i would do is bypass the fuel pump relay and make sure the fuel pumps are operating.
J man
Re: volvo sx stall
stall as if someone turned the key M/N 57faplkd S/N t01298386
bruceb58
Re: volvo sx stall
Sure sounds like the fuel pumps operate during the cranking and then stop shortly after.
Check your fuel pump operation.
