Volvo /OMC sea water pump 3858847. 6.5 inch pulley
Saw older post here by Sparkinator, it seemed to say you could change the shaft seal behind the impeller without disassembly of the pump(as long as bearings turn smooth).
Seal is. SKF Rotary Shaft Seal: 1 Lip w/Spring, HMS5, Nitrile, 16 mm ID, 28 mm OD, 7 mm Wd
Item 40J957Mfr. Model 16X28X7 HMS5 RG. Far as I know this is the seal.
Any one know if possible,?? As I do not have reputable repair where I am....(usually they cost way more in labor & excess parts unnecessarily needed.) Nor do I have a press etc.
Thanks
ron3033
Thanks
ron3033
