Augoose
- Mar 21, 2010
- 1,220
I read a few forums today and it seems an ongoing issue for the 1994-1998 SX drives is cracking of the starboard side upper gear housing, right below the middle mounting stud. This happened to a drive I just purchased, and over the last two days alone on this forum I've seen two other threads dealing with SX drives with cracks in the EXACT same spot as mine. Not sure if it applies to earlier style drives or not.
Seems water gets trapped in that cavity, freezes, expands, and then cracks the housing outward. I read on another forum that Volvo started drilling in a drain hole as a result. When I went and compared that same cavity to my 1999 SX drive, my '99 has a grove (almost looks like a pry mark to help separate the outdrive from the gimbal housing but of course that's not what it is) to let the water drain out.
At any rate, its too late for this season, but hopefully this thread will help someone else next year. Consider making a hole at the bottom of the cavity where the sealing surface of the outdrive meets the sealing surface of the gimbal housing!
