volvo penta sx cobra drive. change rotation?
171mach1
hi, is it possible to change the the prop rotation on my drive. If so would there be any disadvantages to using a counter rotating prop. Btw. 1998 larson 206 lxi 5.0l volo penta /sx cobra drive. Thanks
HorizonblueDK
Re: volvo penta sx cobra drive. change rotation?
Yes, you can change the drive rotation on the SX Cobra drive. Take off the plastic cover, on the upper gear housing, and move the vertical metal rod to the opposite side. This will change the rotation. (works like older Volvos)
If there are any disadvantages, when using a propeller that goes the other way around, I don't know.
ENSIGN
Move the shift cable to the oppisite lever on the helm control.I don't think there is a performance difference between a cw and a ccw prop.
171mach1
thanks I'll give it a try
